HI All,
I'm trying to figure out how to design the circuit to scale voltage from a TMP01 from Vptat to F.
I have made the circuit that is in the datasheet and it works but I want to learn more about opamp design.
Also, the circuit in the datasheet uses 2 opamps. I know it can be done with 1 using differential inputs.
I have reduced the equation and now I need to figure out to calculate R1, R2, R3, R4
On the TMP01 Vref = 2.5V.
The conversion for Vptat to 10mV/F is:
Vptat*3.6 - 4.6
So at room temperature, and as per the datasheet, 1.49*3.6 - 4.6 = .764 (76.4F)
Just to prove the eqn...
Boiling point = 1.86575
1.86575*3.6-4.6 = 2.1167 (212F)
and freezing
1.36575*3.6-4.6 = .3167 (32F)
The transfer function is:
I need some tutelage on how to tackle finding the R values.
Do you just set 1 or more R values at say 100K and solve?
Whats the approach?
I really appreciate some knowledge here!
Vptat*3.6 - 4.6
and freezing
Whats the approach?
