Voltage regulator
octebra
Joined Jul 4, 2009
1
Hi everyone i'm from Australia and I have a question, I hope someone can help me. I have just purchesed a VAWG that produces upto 15 amps at a maximum of 100v DC, I am worried that if it produces that voltage that it will damage my deep cycle battery. Has anyone any ideas as to how I can ensure this does not happen. All of the regulator I looked at only accept upto 36v which does not seem enough. Is it possible to buid a regulator using a triac. I hope someone can help, thanking you in advance.
Regards octebra.
bertus
Joined Apr 5, 2008
22,955
A triac will only work with AC, when used on DC a firing pulse will turn it on but it will never go off again.
Can you post a drawing of what you want to try to do?
Greetings,
R!f@@
Joined Apr 2, 2009
10,004
Using traics to built battery chargers is a very unusual way. :confused:
As far as I know there are 3 ways to control a charging in a deep cycles, either in CV or CC.
One is using PWM as in SMPS
Second is using a series pass element to control the out put
The third and my favorite is using SCR's in the rectifier to control the charging of SLA or LA's
Traics is a no no no!! :eek:
And when it comes to building,your knowledge on power electronics is very important
Rifaa
R!f@@
Joined Apr 2, 2009
10,004
What about LM723, I think they are well designed and cheap as a regulator, and can operate in either CV or CC. But you have to use Power transistors as series element.
Rifaa
t_n_k
Joined Mar 6, 2009
5,455
Rifaa
Yes, a past colleague used the same IC in a high voltage input regulator - many moons ago. Added a series power device.
I think your earlier suggestion of the switch mode route makes more sense - handling the series pass power in a linear regulator might be prohibitive - especially if using high charging currents at rated output from VAWG.
I'm not sure if the OP [Octebra] is looking for an off-the-shelf solution. Agreed with your observation about necessary experience with power electronic design & construction if it's do-it-yourself.
Appreciate your thoughts and enthusiasm for the forum.
