Hello friends, I am finally in my final stage of my dc-dc converter project for my final year project. My input device is a mechanical hand crank which is a fluctuating output device. Hence I used a LM7809 voltage regulator ic to stabilize the output to 9V. When the output of the hand crank is connected to my buck boost circuit to produce a 13V output I am only getting about 1V to 2V. Due to this failure I attempted another method by creating a voltage regulator circuit with two capacitors 10uF and 33uF with a variable resistor. When connected to the buck boost. I am able to produce about 15V to 13V. Can you guys help me explain why is this happening. Thank you
