Voltage regulator
HarrisonG
Joined Aug 1, 2016
73
Hi. I want to find out if my understandings are right. So this is a voltage regulator with zener diode. Say Vz=5volts. Until the point that the voltage at the zener reaches 5V, the zener remains off. The current equarion is Is=Iz+IL, Is=IL(where IL is the load current). As soon as the voltage at the zener reaches the 5V treshold voltage, it turns on and some minimal zener current flows, determined by this equation Iz=Is-IL. It starts regulating. From now on, we can say that IL=Vz/RL=almost constant. As Vsupply increases, the zener current increases and keeps Vz at almost constant level.
34,807
I would put it differently.
R + Rload constitute a voltage divider.
When Vload > Vz the zener will conduct so that Vload = Iload x Rload = Vz.
hp1729
Joined Nov 23, 2015
2,304
Worth noting, Iz must be greater than IL to keep the output voltage steady as RL changes. Typically 5 to 10 times IL.If IZ max is 50 mA IL must be in the neighborhood of 5 mA to 10 mA. This is a low power scheme.
