Hi guys, am after a little - or a lot of - help...
Have found myself quite stuck with a project currently. Wind turbine (VAWT), using an old washing machine motor as a generator. Produces an output up to 300V 3phase AC, 2-3A unloaded, when used as a gen.
The ultimate goal is to build a circuit that will output either 12 or 24V constant from this turbine. Problem is, how do I do that when (depending on wind speed) the voltage generated is going to vary dramatically anyway.
Rectification of 3ph AC to DC is fine, I can deal with that, it's the regulation that's killing me. I've been told, and from the limited knowledge I've got it seems logical, that a PWM circuit for regulation is the way to go. If so, how do I go about building one? If not, then is there a better option over PWM?
I'm quite stumped and any help would be greatly appreciated. I've been a muppet and left it until the last minute, only a few weeks until the final product is due.
Help!
Help!
