Voltage Reg 0v-10v input with 0v-4.5v output 2A
JKbiz
Joined Mar 20, 2017
16
Hey,
New to the forum and electronics in general. I am trying to find a variable voltage regulator that will take a standard 0v-10v analog dimming input and output at 0v-4.5v dc.
Any help would be greatly appreciated!
Thanks,
Josh
JKbiz
Joined Mar 20, 2017
16
What's your supply voltage?
Where is the dimming signal coming from?
Dimmer signal is coming from an ETC (electonic theater controls) responce pack. I think 0-10 @ 10mA. Supply voltage is preferably 12vdc but I can spec others if there's a reg. that required it.
JKbiz
Joined Mar 20, 2017
16
I could also make it work with a 12v PWM to analog converter as long as the output specs are the same.
#12
Joined Nov 30, 2010
18,224
Missed it that time.:D
Looks like we need a voltage follower with a big transistor to deliver 2 amps.
JKbiz
Joined Mar 20, 2017
16
It is a 3W (so legitimately .6 and change amps) LED element. I may need to run 2 at once so I had the extra amperage for overhead. If I tweak the plan I can, in all fairness, get away with a 1A load.
It's going to be seen on a camera so I can't get away with the slow PWM driver that it comes with.
38,946
Since it's an LED element then it should be completely off at 2V or less.
This means you could use an LM317 regulator to provide the output, as it goes down to <1.3V minimum.
It will output up to about 1.5A, and also provides short-circuit, and over-temperature protection.
Below is the LTspice simulation of that.
Note that at 1A the LM317 can be dissipating up to about 10W, so it needs to be on an appropriate heatsink.
JKbiz
Joined Mar 20, 2017
16
Brilliant!! Thanks all. Looking at this sim graph I think I'm shopping for a LM317. I'll post once I have this one built and we'll see how she looks on camera.
Thanks again,
Josh
JKbiz
Joined Mar 20, 2017
16
Update:
I built this circuit per the diagram but must have missed something as my output voltage doesn't quite match the graph indication.
Kjeldgaard
Joined Apr 7, 2016
475
Do you have a load on the output of the LM317?
Minimum output current is 10 mA for the LM317.
So when the output voltage is to be down to 1.25 V, there must be 120 Ω load and at least 1/4 Watt.
38,946
Typically there's a 120Ω resistor between the output and the ADJ pin, which takes care of the minimum load current requirement if there's no other load, but since you were driving a fixed load of LEDs I didn't think it was necessary.
