Voltage of square wave
ne89
Joined Sep 25, 2006
9
hi all
I want to measure the voltage of 75 Hz bipolar square wave with single ended ADC as voltmeter.
What is the good method to measure it?
I need your help please.
Thanks
beenthere
Joined Apr 20, 2004
15,819
Bipolar into single ended won't work at the ADC. You can use an op amp to offset the square wave to unipolar, although a bipolar ADC might be preferable. You would probably want another circuit to detect the rise of the square wave and then trigger the conversion
What is the magnitude of the square wave?
kender
Joined Jan 17, 2007
264
The most general ways to convert the bipolar into single ended is ti use a difference OpAmp, InAmp or balun transformer. InAmp will give a more precise conversion. InAmp will work for your low frequency.
Could you post a sketch block diagram that shows the source of your bipolar square wave, your adc, power supply and the (common?) ground?
ne89
Joined Sep 25, 2006
9
Thank you for your kindly help
What is the suitable type of general opamp as single supply InAmp for my low frequency?
