Voltage Meter Power Supply
marshallf3
Joined Jul 26, 2010
2,358
Attached is a block diagram of the circuit. I didn't think it was necessary to include the specifics of the amplifier. The voltage meter clearly states that the measured signal cannot share a ground with the meter's power supply. The negatives of the power supplies are not connected directly--although I can measure a voltage between them, and I assume that this relationship is the cause of the problem.
Yup, one of those eBay/China type designs. You'll need a separate supply or a $6 isolation converter.
R!f@@
Joined Apr 2, 2009
10,014
is the opamp properly decoupled
Without the detail schema we cannot be sure.
Instead of asking provides all the details. this way we can help u sooner and better
fredp
Joined Sep 24, 2009
41
The meter is a LASCAR EMV 1125 from Newark. It was pretty expensive. Last one I used was from MPJA was much cheaper and worked fine with separate power supplies.
Maybe I should go back to the cheap one?
Can you recommend an isolator and/or a meter that will work?
marshallf3
Joined Jul 26, 2010
2,358
The isolator would depend on the voltage and current requirements of the meter, mine were the 5V red LED style and I used a NKE0505SC isolator.
Due to all the confusion there are quite a few inexpensive ones on eBay now that will work with a common supply.
