marshallf3
- Joined Jul 26, 2010
- 2,358
Yup, one of those eBay/China type designs. You'll need a separate supply or a $6 isolation converter.Attached is a block diagram of the circuit. I didn't think it was necessary to include the specifics of the amplifier. The voltage meter clearly states that the measured signal cannot share a ground with the meter's power supply. The negatives of the power supplies are not connected directly--although I can measure a voltage between them, and I assume that this relationship is the cause of the problem.
