Voltage inverter
Kelvin Lee
Joined Oct 22, 2018
111
Dear Sir/Madam,
Due to my special requirement, I need to have a pedal to provide a range of voltage to an ECU, unfortunately, the pedal provides 5V when not step down, I need to have a circuit to invert the voltage output from the pedal before the ECU. A friend gave me a circuit but I tried and the voltage output can only several amounts of mA, I refer to the datasheet of 2N3904, the Vce can only provide max 0.4V, I think I have to change another transistor but don't know which one is suitable to my case, do any once can help?
Best regards,
38,718
Tell us exactly what ECU voltage you need for the voltage from the pedal out.
Do you want 0V for a 5V pedal and 5V for a 0V pedal?
What is the ECU load resistance or current requirement?
Picbuster
Joined Dec 2, 2013
1,062
Dear Sir/Madam,
Best regards,
KelvinView attachment 184847
The 2n3904 has a saturation of 0.4V at an ib of 5mA.
Meaning: the voltage between Emitter and Collector can't get lower than .4V
That includes with a 5V power supply the E-C voltage could run from 0.4V to 5V.
Running from zero is, using circuit above, not possible.
We need more info as requested by Crutschow.
Picbuster
Bordodynov
Joined May 20, 2015
3,431
The problem can be solved using single element logic. For example, the SN74AHC1G14 Schmidt trigger. Instead of two resistors and a transistor, one small chip. And "zero, low signal" you will have 0 volts.
Kelvin Lee
Joined Oct 22, 2018
111
Sorry for my late reply. I use the multimeter to test from step up to down, the voltage change from 3.736V to 0.802V and current is from 2.48mA to 0.54mA, I need to invert the voltage from low to high when stepping up to down.
Please note the power supply for the pedal is from the ECU which is 4.565V
Why can't you just do the inversion in software?
Yes, I did it using Arduino but now we need to have a circuit to do.
Thanks, Bordodynov, this is the first time I hear about it, may I know if I give 4V input what is the output voltage?
Bordodynov
Joined May 20, 2015
3,431
With a power supply of 4.565 V and an input signal of 4 V, the output of the microcircuit will be 0 V. If you need a digital output and some specific threshold, then you can use a comparator. Another possibility when using the Schmidt trigger is to eliminate switching bounce. To do this, you need to put a capacitor at the input of the microcircuit and that's it.
Kelvin Lee
Joined Oct 22, 2018
111
Thanks, but it is too complicated to me.
BobTPH
Joined Jun 5, 2013
11,621
An opamp is far superior to any transistor circuit you are likely to make. Basically you would have to make an opamp from transistors to do what you want using discrete components.
Bob
Kelvin Lee
Joined Oct 22, 2018
111
Bob
Thanks, Bob but I am a newbie to this, no idea to the opamp you mentioned.
BobTPH
Joined Jun 5, 2013
11,621
An opamp is the triangle in @crutschow’s circuit in post #10. They come in many flavors. You would need a single supply opamp like the LM358. The circuit is easily adjusted to output 3.5-0V with 0-5V input.
Bob
Kelvin Lee
Joined Oct 22, 2018
111
Bob
Many thanks, Bob, I understand the opamp solution is better than using a transistor, as this is a student project, it may not be the perfect solution but we do have limited resource, can we simply replace another transistor and make it done? This solution may not be accepted by the most experienced circuit designer.
Alec_t
Joined Sep 17, 2013
15,150
..... but the LM358 input voltage must be at least a couple of volts (approx) below the +ve rail, implying you'd need a supply voltage >=7V.
38,718
It's not a matter of acceptance.
It's performing that function reasonably well with just a couple transistors.
What is the exact input voltage range you have for a 0V to 3.5V output?
38,718
Okay, here's a single transistor quick and dirty circuit that will likely be frowned upon by many but it's simple.
The circuit function uses the value of transistor current gain (Beta) for its operation and is thus significantly affected by the gain of the particular transistor you use (since the gain can typically vary by a a 3:1 range unit-to-unit).
This means you will have to tweak the 250k Ω pot U1 and possibly the value of R1 to get the desired transfer function.
The circuit is also sensitive to ambient temperature so, if that varies significantly, the circuit may not perform satisfactorily for your application.
