1)Hi Eric, did u mean the column i highlight in red color stand for maximum current at the voltage state?hi LF,
That Table shows the Maximum rated current loads for AC and DC, inductive and resistive.
Is this what you are asking.?
E
Hi, i want to connect a 12V dc motor to be control by the relay. It is applicable?hi,
The entry in that table below the one you have marked in Red, states the maximum Voltages and currents.
What Voltage and current values are you requiring to switch with the relay contacts.?
E
Hi, below is the specification for the motor to be control by relay. Is it ok if i use LY4N DC24 to control it?hi,
OK, do you know the current or power rating of the motor.
It should be printed on the motor casing, if not not, do you have the motor model details, we could find the data on the web.
E
