Voltage for Load that connected to LY4N DC24 relay
Lemon_Foam
Joined Sep 18, 2017
40
1) I'm using the relay LY4N DC24 to build a circuit for control some load. From the specification, i found that the load can be connected to AC110V and DC24V only? If my load use DC 12V, can i connect it to the relay?
2) How did i distinguish between resistive and inductive load?
ericgibbs
Joined Jan 29, 2010
21,649
hi LF,
That Table shows the Maximum rated current loads for AC and DC, inductive and resistive.
Is this what you are asking.?
E
Lemon_Foam
Joined Sep 18, 2017
40
hi LF,
E
1)Hi Eric, did u mean the column i highlight in red color stand for maximum current at the voltage state?
If i use voltage other than the voltage stated in red highlighted region, it is still acceptable?
2) I also want to know what is the different between resistive and inductive load
ericgibbs
Joined Jan 29, 2010
21,649
hi,
The entry in that table below the one you have marked in Red, states the maximum Voltages and currents.
What Voltage and current values are you requiring to switch with the relay contacts.?
E
Lemon_Foam
Joined Sep 18, 2017
40
hi,
E
Hi, i want to connect a 12V dc motor to be control by the relay. It is applicable?
ericgibbs
Joined Jan 29, 2010
21,649
hi,
OK, do you know the current or power rating of the motor.
It should be printed on the motor casing, if not not, do you have the motor model details, we could find the data on the web.
E
Lemon_Foam
Joined Sep 18, 2017
40
hi,
E
Hi, below is the specification for the motor to be control by relay. Is it ok if i use LY4N DC24 to control it?
ericgibbs
Joined Jan 29, 2010
21,649
hi LF,
That relay will be OK.
It is common practice to add a 'snubber' circuit across an inductive load [ motor] in order to protect the relay contacts.
A 100nF capacitor and 120R resistor in series across the motor, as a snubber is recommended.
E
