Voltage division, please help
Dafinc
Joined Feb 16, 2018
i have to apply voltage division to this circuit to express the Output voltage across the Rp resistor.
these are my calculations but i cant figure out if they are true or if it is the right way to do it:
Rs = 6 Ohm.
Rp = 1 Ohm
Vs = 8V
Vo = 8V * 1ohm/6ohm + 1ohm = 2,3333 V
Using the Calculator on this website gives me a different value.
LesJones
Joined Jan 8, 2017
4,543
Since when did 8 divided by 7 = 2.3333
Try doing the division again. First longhand on paper and then do it with a calculator.
Les
Dafinc
Joined Feb 16, 2018
I think i got the right answer now.
instead of typing 8 * 1/6+1 = 2,33
i typed 8 * 1/7 which gave me the value 1,1429V
which is the same value as the calculator gives me.
InPhase277
Joined Feb 15, 2018
23
The order of mathematical operations is fundamentally an artificial construct, but we have to agree across the board, so someone in the past set the standards: PEMDAS
Parentheses first, Exponents, Multiplication as they appear, Divisions as they appear, Additions and Subtraction as they appear.
Your calculator knows this, hence the incorrect answers.
Bordodynov
Joined May 20, 2015
3,431
I think the problem is inattention.
Stop mocking the man!
What I show below is also a learning process. If the author of the topic understands that I wrote, it will be progress in learning.
Vo = 8V * 1ohm/(6ohm + 1ohm) = 8V/1Ohm/7Ohm=1,142857142857V
i=Vs/Rser, Rser=Rp+Rs, Vo=i*Rp=Vs/Rser*Rp=Vs*Rp/Rser=Vs*Rp/(Rp+Rs)
dl324
Joined Mar 30, 2015
18,462
Either you need to learn how to do arithmetic or you need to learn how to use a calculator.
The equation you're trying to solve is:
\( \small Vo = Vs * \frac{Rp}{Rp+Rs}
Vo = 8V * \frac{1 \Omega}{1 \Omega + 6 \Omega} = 8V * \frac{1}{7} = 1.14V
If you had kept track of units, you would have noticed that the equation first used wouldn't give Volts. This would: 8V * 1Ω/(6Ω + 1Ω).
InPhase277
Joined Feb 15, 2018
23
One of the biggest problems that I see made with math involving physical units is that people forget that the units themselves have to undergo the mathematical massaging just like the numbers.
One of the first things to do with an incorrect answer is check to see if it is dimensionally correct.
MrAl
Joined Jun 17, 2014
13,791
Rs = 6 Ohm.
Rp = 1 Ohm
Vs = 8V
Just a little note here...
Normally when we do a voltage divider we use the formula:
Vout=Vin*Rd/(Rd+Ru)
where when the circuit is drawn like that:
Rd is the lower resistor (down),
Ru is the upper resistor
This gets you there quick.
(I think you started to do this right but just didnt do the math right perhaps.)
You might ask the question why this works though.
The reason is because when the output voltage is solved as above, the current through BOTH resistors is the same.
You can look at Kirchoff's Laws to find out more.
WBahn
Joined Mar 31, 2012
33,178
Rs = 6 Ohm.
Rp = 1 Ohm
Vs = 8V
In order to get this result, you are interpreting the equation as
Vo = (8 V * 1 Ω / 6 Ω) + 1 Ω
However, while the expression in parentheses is 1.667 V, you then need to add this to 1 Ω and you can't add a voltage to a resistance. It's like asking what 3 feet added to 2 pounds is. It's fundamentally nonsensical.
So the biggest, most important lesson you can possibly learn from this exercise is to always, always, ALWAYS properly track your units. Most mistakes you make will mess up the units, as your mistake here did, but only if you track them. You can't just tack on the units that you want the answer to have at the end, which is what you did here.
This is actually a very, very common mistake. Humans are used to writing
A \; = \; \frac{B}{C+D}
and when we then put this in an in-line text form there is a natural tendency to just replace the horizontal line with a forward slash and get
A = B/C+D
But the horizontal line did more than just indicate a division operation, it also acted as a grouping operator, thus the proper translation should be
A = (B) / (C+D)
Without those parens, we have
A = (B/C) + D
which is a very, very different expression.
Now, sadly, no calculator that I am aware of lets you track units. There have been some computer programs that have at least tried to do that, but I've never run across them. So when you go to plug numbers into the calculator, you have to understand it's order of operations well enough to know that it is doing what you want and, if not, how to override them to force it to do what you want. One of the best things you can do is estimate what you expect the answer to be before you plug the numbers into the calculator and if the value you get when you do isn't in line with it -- stop. Figure out whether you are using the calculator incorrectly or you are estimating poorly. In this case you have an 8 V source supplying current to a circuit with a total of 7 Ω, so the current is just a little more than 1 A. The voltage across the 1 Ω output resistor is thus going to be just a little more than 1 V. It is NOT going to be something over 2 V, so when you get that answer, all kinds of red flags should go up.
So:
1) Always, always, ALWAYS track your units properly throughout your work.
2) Always, always, ALWAYS ask if the answer makes sense.
WBahn
Joined Mar 31, 2012
33,178
So, according to your description, the following expression
X = 64 / 4 * 8
should yield a value of 2.
There are no parens or exponents.
You then say Multiplication as they appear. That means it becomes
X = 64 / (4 * 8)
But the universally (as far as I am aware) agreed upon rules for order of operations state that multiplication and division are of the same precedence and are left associative and that, likewise, addition and subtraction are of the same, albeit lower, precedence and also left associative.
Thus
X = 64 / 4 * 8 = (64 / 4) * 8 = 128
WBahn
Joined Mar 31, 2012
33,178
You might want to review your equations. You have a typo there.
There was a TV comedian who would have said to you: "You don't get out enough!"
The 25+ year old HP48 calculator could track units and a number of its descendants still do. Here's the TS's calculation as he typed it in, shown on my HP50G calculator. Sorry for the slightly blurry images:
Now if I press the "ENTER" key the calculator does some calculations, keeping units:
Now I press the "EVAL" key in an attempt to combine units:
But if I type in this:
And then press "EVAL", I get this:
