Thank you for the input. This is ALL helpful. It seems the first thing I should do is a test like I did for the 12v refrigerator in my van because they are similar in the sense that they run and they sleep. so for the fridge I hooked up a multi meter, turned on the fridge and it drew 5 amps for 2 minutes (the compressor) when the compressor shut off it only drew .08 amps for the following 5 minutes. then repeated. I did this with a stop watch for 1 hour then tallied up the whole thing and got a pretty good estimate of how many amps it would draw in (1) hour. There might be an easier way but I couldn't think of one. I'll do this with my new project and then I will be able to answer your first question accurately. Thanks ALL, have a great weekend, FredThere's no way to know if this will be adequate without more information about your application. What is the current draw that you need? How long do you need the batteries to last?
What is the highest and lowest voltage that your system can run properly on? Is that what the 3.5 V to 5 V that is mentioned in your first post refers to?
The effective capacity of alkaline batteries is pretty sensitive to the actual current draw. In general, the higher the current, the less the available capacity is.
