I'd like to get opinions in regard to this. I've been given an assignment in which I need to find a way to hook up mains voltage (up to 600Vrms) to a Labview CompaQ Daq with module NI 9201. It accepts a -10V to 10V signal, and provides isolation up to 2,300Vrms from other modules in the system.
Generally, most people say do not use voltage dividers from mains unless you know exactly what you are doing. I'd like to use a voltage divider to reduce the high mains voltage to a -10V to 10V signal. Would this setup be considered 'safe' given the high isolation voltage of the module?
