Voltage divider equation to find voltage into the circuit...
callmedave
Joined Jan 11, 2019
5
Hi
I am trying to answer a question where I need to use the general formula for a voltage divider to find the voltage in.
I have rearranged the general formula as follows:
Vout = Vin * Rother / Rtotal
Vin = Vout * Rtotal/ Rother
but i can't come to the correct answer, could someone please tell me if this is due to my rearranging being wrong?
Thanks...
WBahn
Joined Mar 31, 2012
33,309
Hi
Thanks...
I'm guessing that your problem is that you are using the wrong resistor when you say Rother.
An equation is meaningless unless it can be tied to a specific circuit layout. Draw a schematic that clearly shows where Vin in measured, where Vout is measured, what the resistors are and how the individual resistors relate to Rother and Rtotal.
dl324
Joined Mar 30, 2015
18,490
It would best for you to learn early that it's best to post a schematic when discussing a circuit; even one that seems (to you) to be simple.
A voltage divider doesn't necessarily need to be for two resistors.
We can tell that your arithmetic is correct, but we have no way of telling whether either equation is correct.
BobTPH
Joined Jun 5, 2013
11,665
So, we can see the output voltage on your diagram, and the ? I guess is the input voltage. What do you think Rother and Rtotal are?
Bob
dl324
Joined Mar 30, 2015
18,490
This is the circuit I'm working on, it's actually asking for the Thevenin equivalent voltage
Is there supposed to be something in the box with the 560k resistor? Are the circles (on the voltage source) meaningful?
Where's the voltage divider?
WBahn
Joined Mar 31, 2012
33,309
Draw you circuit as a meaningful circuit. If the box is being modeled as a Thevenin equivalent, then draw the equivalent circuit, which is a voltage source in series with a resistance.
What is the box on the right that is labeled 53.48 μV? Is that a voltage source? Does it represent a voltmeter? What is the importance of the circle on top being open and the circle on the bottom being closed (filled in)?
In terms of this diagram, what you you saying that Rother and Rtotal are?
You need to communicate your work clearly and unambiguously. Not just here, but to whoever will be grading it, too.
