Im after a few ideas,
I'm looking to be able to detect when a pin has been connected to a voltage,,,
sort of like a power on reset circuit,
BUT
I need it to be low power
I need to give a "logic" output ( 3v3 or 1v8 )
The voltage in, I need to detect when its above say 5v , but the input can go up to 30 volts,
The circuit needs to be safe when the say 30 volts is connected, but the circuit is not powered.
Things I have considered,
opto isolator, but the resistor needed on the led is a problem,
resistor / zenar, into a logic gate. Resistor power gets high when 30 volts in,
comparator, but cant find one thats safe with no power and 30 volts in,
Any thoughts ?
BUT
Any thoughts ?
