Voltage conversion 100V to 120V
35,245
Try installing an incandescent light bulb in series with the heater.
Start with a 100 W bulb and see if that works. Measure the AC voltage across the heater.
Ian0
Joined Aug 7, 2020
13,298
You need 5Ω in series. A 120V 100W lamp has an operating resistance of 144Ω, so will be about 20Ω when cold. A 24V 100W lamp might be close.
35,245
I am aware of the resistance change with temperature. One would have to experiment with the wattage of the lamp to see what works. I expect that the lamp may just glow red.
Ian0
Joined Aug 7, 2020
13,298
Red heat is 900K to 1000K: filament lamps are almost PTAT, and Normally run at 2700K to 3400K, so the resistance would be about a third of normal operating resistance, 48Ω for the 100W 120V lamp.
35,245
We need about 5Ω @ 100W.
I don't know where you can find a 24V 100W lamp.
Put two 12V 50W lamps in series.
28,454
An "AUTOTRANSFORMER" connection of a regular transformer is an excellent scheme. Of course, it is often better because the boost winding current rating is greater, since the boost winding carries the total load current.
du00000001
Joined Nov 10, 2020
201
That one is a fancy Chinese cap that comes with a number of differing denominations but looks too small for being permanently powered. The most informative link I found is the following:
https://jennyli168.en.made-in-china...citor-CD60-150UF-250V-AC-Start-Capacitor.html
(This one shows dual faston contacts for both terminals.)
Here it is denominated explicitly as "starting capacitor" - as well as others looking similar. I would not leave this unsupervised while trying to boil water ;-(
