First you tell us what the output pulse voltage, frequency, and pulse-width are, also the bulb wattage or current.what do I do..?
I've IRF3205 mosfet...how do i connect it.You can use a MOSFET to control the bulb current.
Where can you buy parts?
Connect :-how do i connect it.
Wow...perfect...it worked just fine..thought the 555 cant operate on 12v..thanks..Connect :-
the FET gate to pin 3 of the 555,
the FET source to ground,
the bulb between the FET drain and the 12V supply.
Remove the 7805 regulator.
Drive pins 4 and 8 of the 555 directly with the 12V supply.
Its data sheet tells all.thought the 555 cant operate on 12v.
Yh...guess I misssed out..actually that was first stage..now i have my pulse signal able to light up the 12v bulb..the initial plan was having 2 12vbulb..bulb A flashes 5 times and stops b alsso flashes 5 times and stops then A and B flashes 5 times and stops..then it recycles if possible..i've got couples of relays and timers..i already generated pulse that can help make the bulb go on and off..Its data sheet tells all.
by Jerry Twomey
