Vintage electronics - Old Time Clock machine - where to start ?
Todd W. Roat
Joined Jun 7, 2015
21
So I bought this old Cincinnati Manufacturing circa 1950 time clock machine. Really just bought it for the Cincinnate referenc e(Im in Cincy) and because it was just kind cool.
When I took it apart all the mechanicals for the clock and other mechanisms were still it very good shape. So I began wondering if, with electricity, the machine could be used as a clock.
I don't know that much about electricity other than basic wiring (home, motorcycle, etc). While the electronics in here look basic there a couple components I don't recognize. See pix. Esp. the cloth wrapped components in last image.
So basic questions:
  1. Should I even try ;^)
  2. Little afraid to just plug it in. Way to test it with voltmeter first?
  3. Any and all input welcome.
Brevor
Joined Apr 9, 2011
297
From the photos you posted it looks like all it needs is a new power cord. Maybe use a precision oiler to lubricate the moving parts with some machine oil.
dl324
Joined Mar 30, 2015
18,326
Last picture looks like a transformer. A picture of the tag on the bottom would give more clues.
Be mindful of polarity when you rewire.
12,126
Or is the last photo the motor; I see only one coil with only two wires. Most of the insulation on just about everything looks shot, but there are no obvious shorts in the photos. If you start to remove electrical parts, be prepared for a lot of that insulation to crumble away.
Lestraveled
Joined May 19, 2014
1,946
If you have an ohm meter, measure the resistance across the power plug. If it reads less than 10 ohms then there is probably a problem. Over 50 ohms and I would plug it in and go for it.
Hypatia's Protege
Joined Mar 1, 2015
3,228
So basic questions:
1) IMO absolutely!:)
2) And well you should be... considering the condition of the power cord!:eek:
3) OK then! Here goes...:D
FWIW: The laminated device in the 'last' image appears to be a 'skeleton-style' shaded pole motor -- and, in fact, upon 'zooming in' one can barely descry the word 'motor' on the nameplate.
When you restore the unit you will need to replace the power cord, dissemble, clean and lubricate the motor, clean any electrical (switch) contacts (which, if present, will likely take the form of linkage-actuated switch-reads bound near one end with Bakelite (i.e. phenolic) insulation --- of course the mechanical components may likewise require cleaning/lubrication...
Finally -- prior to connecting the unit to the mains, please check for line to chassis leakage!!! --- In any event it is advisable to consider grounding the chassis (Via a three conductor power cord)
Best regards and good luck!
HP:)
Todd W. Roat
Joined Jun 7, 2015
21
Thanks for all the input. Will try to get some more pix, although the rest is all mechanical not electrical. Here is a picture of the "Motor":
I would also like to try and replace that old two prong plug with a vintage one, but cant find anything like it online. The prongs have an odd pattern (spring type?) to them. Picture 2.
What gauge would you guess that to be in the power cord?
Hypatia's Protege
Joined Mar 1, 2015
3,228
A 16 AWG (stranded) cord should 'fit the bill' --- If you will not be 'upgrading' to a grounded power cord/connection please consider operating the unit only from A GFCI protected receptacle...
Interesting motor!:) -- That's the first 'skeleton frame' synchronous motor I've seen -- A vintage piece indeed!:cool:
Best regards
HP
...You need a new power cord.
Indeed! I think we're all agreed that a replacement power cord is essential -- My point was that the OP may wish to consider 'upgrading' to a grounded power cord -- apologies if my post was unclear...
That style motor was very common back in the day.
I'll take your word for it!:) --- FWIW My recollection of small synchronous motors is that of gear-motors housed in 'hermetically sealed' metal 'cans' --- Whereas skeleton frame motors were, generally (non-synchronous) shaded pole types commonly seen in (phonograph) 'turn tables' and, of course, cooling fans in the ubiquitous Tektronix 'boat anchors':D
With Nostalgic Regards
HP:)
IMPORTANT: @Todd W. Roat Please read!
I notice the numeral '1' in the AV (i.e. ' RPM') field of the motor's name plate --- This implies that the motor assembly contains a gear-reduction mechanism -- If the motor works, Please disregard my advice as regards disassembly of the motor (in post #8)! --- Should the motor fail to operate please let us know -- there are a few useful 'kinks'...
Best regards
HP
Todd W. Roat
Joined Jun 7, 2015
21
Thanks again for the help gentlemen. I got the electric fixed but as one might suspect the motor is sluggish. Turns a bit, stops, with a little nudge it goes again, stops, nudge, etc. I read a bunch of articles about getting oil inside the "can" by heating the motor then adding oil to drive spindle - as it cools at it vacuums in. Worked great. But didn't help. These motors are $100 bucks on ebay or $160 rebuilt. Not THAT interested in the project. Against what Ive read im considering cutting a door in the can motor to peek inside and see if I can get out any old dried lubricant sludge Im hoping solidified and is causing my issue. Motor is an B style motor: B3 HNK M2510 1 RPM.
Probably your best last option -- I would suggest, however, that said 'incision' is NOT made with a grinding tool! -- Lest the unit 'bite the dust' once and for all:eek:;)
Good luck and please keep us posted!:)
HP
On second thoughts --- Perhaps you could drill a small hole then gently heat the unit (to perhaps 120 Deg [C]) so as to facilitate drainage of the viscid lubricant --- note also that volatile solvents may be useful in this regard...
Best regards
HP
GopherT
Joined Nov 23, 2012
8,009
What kind of oil did you use?
If you are set on trying the hole, I would use a 3/16" bit (sharp and new) and drill with moderate pressure to make some nice sized turnings/chips. Stop as soon as you see a through hole. Pull all the chips away with a good magnet.
Don't use a fine bit because too much crap will fall in.
Also, you can try to keep the turnings on a nearby magnet while you drill if you can recruit some extra hands.
Finally, drill deep enough that you can get oil out.rinse repeatedly to dissolve the sludge. You may try a solvent but make sure it is completely dry and odor free before plugging it in - don't make any sparks.
