Help identifying a piece of vintage electronics.
QcyDJ
Joined Dec 21, 2022
Hello and thank you in advance. A friend of mine picked this up while out scrapping one day. It came in a homemade box made out of old fiberboard. At first i thought variac, then I did some research and came up with variable resistor/rheostat. I feel like its some kind of transformer, but I haven't applied any power to it. I would like to find a way to use it if possible so any information would be appreciated.
dl324
Joined Mar 30, 2015
18,463
Welcome to AAC!
It looks like a rheostat to me.
It's inadvisable to apply power to some unknown component. If it's a transformer, you can use an ohmmeter to identify the windings. If it's a rheostat, you can measure the resistance.
hexreader
Joined Apr 16, 2011
619
I agree with dl324
I reckon it is likely to be a rheostat - used as an early form of mains light dimmer
I used these at school to raise and lower light levels for spot lights during amateur dramatics performances.
Would need closer examination to be sure
Early 'Variac' ? ;)
Just a WAG on what I see.
My guess evidence is the presence to two different sizes of wires of opposite sides of the device like a step-X transformer. The old school fiber wiring insulation seems to indicate larger gauge wires on the top coil loop than the thinner wires to a possible inner coil loop. The wires to the two slider taps looks to be modern plastic insulation soldered to the taps for some later application of the device.
Physical examination with a multi-meter is needed to be sure.
QcyDJ
Joined Dec 21, 2022
Welcome to AAC!
Welcome to AAC!
Thank you Dennis.
I did take the multimeter to it and should have posted that. The two large wires which could be the "primary" .5ohm and had continuity from both wires to both of the sliding contacts. the 2 small wires at the other end don't seem to have continuity, so no reading from them. they were connected to an old non polarized mains plug when i got it.
dl324
Joined Mar 30, 2015
18,463
A transformer needs to have at least 2 windings.
Thank you Dennis.
For my guess that seems to mean it's bad (open in the primary) to me as the two wires connected to the mains plug would be the primary and the 0.5 coil would be the secondary in a step-down transformer.
QcyDJ
Joined Dec 21, 2022
Update. I removed the varnish of the ends of the two small wires from the inner coil and I do have continuity and the resistance is 8.4 ohms. Outer coil large wire is .4 ohms and inner coil smaller wire is 8.4 ohms.
sparky 1
Joined Nov 3, 2018
1,218
The laminated stamped metal plates means AC. If it has a primary and secondary what is the ratio?
The Role of the rheostat like coil and arm is likely for AC voltage adjustment.
A low current audio signal like 60 Hertz might help determine the input and output of the transformer.
The coil shape may have been square in order to save space. The core dimensions may have been practical
in order to fit the wire and obtain a rated VA it was necessary to extend length. Wire size relates to the amperage.
Ramussons
Joined May 3, 2013
1,572
From the photos, it is NOT a Rheostat ( a variable Resistance). The coil is on laminated core and enanamelled.
I would take it as an early form of a Variable Auto Transformer.
