Vintage 6v Motorcycle Horn Repair
vu2nan
Joined Sep 11, 2014
357
It may not be a DC horn that's driven by a battery, but an AC one that's driven by a bike magneto.
A DC horn requires interrupter contacts, with contact pressure adjustment, which the horn in question does not appear to have.
Here's the schematic of a DC horn.
Nandu.
Dodgydave
Joined Jun 22, 2012
11,395
Hi, sorry for the delay in replying, I have had family to stay. This s a video of how the horn was assembled.
https://photos.app.goo.gl/F9Qxj3EVmUNti2EX7
Hi Daniel, looking at the set up of the horn it must be the square plate that makes the noise, but i would have thought it would need AC to work..
What is the wiring diagram for your motorcycle, does it show how it's connected?
Motorcycle model number?
DanielHowden
Joined Nov 8, 2019
65
Damn, I'm such a dummy, yes this must be an AC horn as it does run from the generator. Having said that, it still did not work on an AC current. I wonder if someone would kindly teach me how the AC horn works so that I can look at fixing it.
Daniel.
Dodgydave
Joined Jun 22, 2012
11,395
Can you post a picture of the wiring diagram of your motorcycle, we need to know what voltage is applied to the horn the ones one the internet are for 12V? , also the generator will vary in frequency as it revs up and down..
ThePanMan
Joined Mar 13, 2020
954
If it's generator powered then it must be getting a pulse from that generator. As the engine speeds up the pitch of the horn goes up. As the engine speed slows down the pitch of the horn goes down.
Quick test: Assemble it and tap the two wires to the battery. It should click and when you remove the wire you should see a serious spark. Don't be touching the bare wires when you do that or you'll curse my name. If that works then the horn is good according to how you're suggesting it works. OR you can take an ohm meter and check for continuity from terminal to terminal. Though I don't see any reason why, the horn wiring may have cracked and become an open circuit. An open circuit means there's no current flowing through the coil.
One quick question: Is the diaphragm magnetic? I mean does metal stick to it? If so then when the AC sine wave goes one way the diaphragm will move similarly. When the AC sine wave switches and goes the other way so will the diaphragm. Basically - is there a magnet in the center of the diaphragm?
Ya’akov
Joined Jan 27, 2019
10,370
The TS has already reported that the diaphragm is pulled to the pole piece and held there until the power is removed.
DanielHowden
Joined Nov 8, 2019
65
OK, so I don't know if the disc in the centre of the diaphragm is magnetic but I will check. The coil inside the horn does produce a magnetic field and does pull the diaphragm on to it until the power is released.
I will check the continuity between terminals.
Ya’akov
Joined Jan 27, 2019
10,370
The disc will not be a magnet, but it will be a ferromagnetic material (at least partly iron). At this point I am convinced that the horn is expecting a pulsating DC or AC input. There is no provision for the switching required by an interruptor type horn.
I am betting now the horn is wired to the stator, before the rectifier regulator.
MisterBill2
Joined Jan 23, 2018
28,651
The very first thing, looking at the circuit, is that the horn has TWO CONNECTIONS! A Blue wire that get connected to fram ground (common) and a yellow wire that also is the power feed for some lights. So the horn is missing a connection! Next, others should examine the brake lights arrangement, which looks to me that the brake light switches are normally closed, which is reasonable because they are in series. PLUS, see the note: "Blue wire must be grounded to run."
This is an AC electrical system!!! So it is indeed an AC horn. And it is missing a terminal. Never would have noticed that if we had not seen the circuit diagram. Seeing the diagram told me a lot: First, there is no battery so probably no DC. Then, seeing that the horn has two connections, and case ground is not one of them , That tells me that the electrical system is quite different. IT IS AN AC SYSTEM!!!
And OF COURSE!!! That is why the six volt horns I put on a car many years ago had two isolated terminals that enabled me to put them in series. They had no horn relays! one side went to the battery positive, and the horn switch on the steering wheel grounded the other side. That is why the horn always stuck on when vehicles crashed in front.
Now it all makes perfect sense.
And the horn in question has the damaged terminal connection shorted to the case because the plastic melted when somebody tried to solder a wire to it.
Autobike General Electronics Chat 6
