Video signal
Dadu@
Joined Feb 4, 2022
155
I'm trying to understand how low power microcontroller generates the video signal that displays on the screen ( games).
I think the video that we see on the screen is made up of many images and an image is made up of one frame. A frame consists of multiple vertical and horizontal scan lines. A frame in PAL format consists of 625 lines.
I want to understand how long it takes to generate one scan lines and how these scan lines are sent to the display.
35,029
Low power MCU does not have enough computational power to generate real time video.
By low power do you mean low power consumption or low processing power?
So it depends on what application and device you refer to.
If it is a game application, it is more likely to be running an ARM based MCU with a graphics accelerator chip.
I have developed a device that generates VGA video using an ARM MCU and no other hardware.
It (a low power microcontroller with the needed hardware module functionality) can generate simple video and text compatible with old school scanning displays and maybe still have spare cpu power for a simple game.
https://forum.allaboutcircuits.com/threads/pic18-q43-ntsc-b-w-video-signal-demo.175611/
C:
#include "ntsc.h"
volatile uint32_t vcounts = 0;
volatile uint8_t vfcounts = 0, scan_line = 0, vml = SL_V1;
volatile bool ntsc_vid = true, task_hold = true;
volatile enum s_mode_t s_mode;
volatile uint8_t vsyncu[V_BUF_SIZ] = {0}, *vbuf_ptr;
void vcntd(void);
void vcnts(void);
uint8_t reverse_bit8(uint8_t);
 * lsb to msb to display chars correctly
uint8_t reverse_bit8(uint8_t x)
    x = ((uint8_t) ((x & (uint8_t) 0x55) << 1)) | ((uint8_t) ((x & (uint8_t) 0xAA) >> 1));
    x = ((uint8_t) ((x & (uint8_t) 0x33) << 2)) | ((uint8_t) ((x & (uint8_t) 0xCC) >> 2));
    return(uint8_t) (x << 4) | (uint8_t) (x >> 4);
 * setup the data formats and hardware for the DMA engine
void ntsc_init(void)
    uint16_t count = 0;
    uint8_t char_c = 0, char_n = 0;
     * Interrupt driven task manager
     * after the H sync pulse there are V syncs with no video
     * main-line code runs for the duration of one timer 4 interrupt period
     * ~200us for testing, then goes back to idle
     * until re-triggered the next H sync cycle
    TMR4_Stop();
    TMR4_SetInterruptHandler(vcntd);
     * setup system arbiter to share memory with DMA process
    // This function is dependant on the PR1WAY CONFIG bit
    PRLOCK = 0x55;
    PRLOCK = 0xAA;
    PRLOCKbits.PRLOCKED = 0;
    ISRPR = 1;
    DMA5PR = 2;
    MAINPR = 3;
    PRLOCK = 0x55;
    PRLOCK = 0xAA;
    PRLOCKbits.PRLOCKED = 1;
     * DMA hardware registers data setup
    DMA5_StopTransfer();
    vbuf_ptr = vsync;
    SLRCONB = 0xff; // reduce PORTB slewrate
    DMA5_SetDCNTIInterruptHandler(vcnts);
    DMASELECT = DMA_M;
    DMAnCON0bits.EN = 0;
    DMAnSSA = (volatile uint24_t) vbuf_ptr;
    DMAnSSZ = DMA_B;
    DMAnDSZ = DMAnSSZ;
    DMAnCON0bits.EN = 1;
    TRISB = vml; // video bit , on
     * setup the static V, H and video patterns for DMA transfer engine to LATB
    for (count = 0; count < B_START; count++) {
        vsync[count] = SYNC_LEVEL;
        vsyncu[count] = SYNC_LEVEL;
        hsync[count] = SYNC_LEVEL;
    for (count = S_END; count < B_START; count++) {
        vsync[count] = BLANK_LEVEL;
        vsyncu[count] = BLANK_LEVEL;
    char_c = 7;
    for (count = V_START; count < V_END; count++) {
        vsync[count] |= BLANK_LEVEL;
        vsyncu[count] |= BLANK_LEVEL;
        if (count > SL_DOTS) {
            if (++char_c > 6) {
                ntsc_font(20 + char_n++, count);
                char_c = 0;
    for (count = V_END; count < (V_BUF_SIZ - 1); count++) {
    for (count = (DMA_B - 5); count < (V_BUF_SIZ - 1); count++) {
        hsync[count] = BLANK_LEVEL;
    for (count = V_H; count < (V_H + 10); count++) {
        hsync[count] = BLANK_LEVEL; // double speed H pulses
    // default scan mode to all lines
    s_mode = sync1;
     * kickstart the DMA engine
    DMA5_StartTransfer();
    TMR4_StartTimer();
 * Encode the font 'rom' into display memory format
 * two 256 byte banks for each display line, split into 4 bits per bank
 * It's possible to optimize 7 bits for one bank per display line but
 * I'm using port B so need to share the pic programmer lines on 6 and 7
void ntsc_font(uint16_t chr, uint16_t count)
    uint8_t cbits, i;
    for (i = 0; i < 8; i++) {
        cbits = reverse_bit8(fontv[(chr * 8) + (i)]); // flip bits for proper display
        vsync[count + i] |= ((cbits & 0xf0) >> 3) | BLANK_LEVEL; // mask and shift to upper/lower banks
        vsyncu[count + i] |= ((cbits & 0x0f) << 1) | BLANK_LEVEL;
 * low priority idle task for timer 4 ISR
 * waits checking task_hold until its false (set to false in DMA state machine)
 * this task is interruptible from all high pri interrupts and control returns after high pri processing
 * when it exits the hold loop, program flow returns to main for application processing
 * until another timer 4 interrupt returns program flow to here.
void vcntd(void) // each timer 4 interrupt
    S_SET_Toggle();
    TMR4_Stop();
    task_hold = true;
    while (task_hold) {
    S_SET_Toggle();
 * NTSC DMA state machine
 * ISR triggered by the completed DMA transfer of the data buffer to PORTB
 * Generates the required HV sync for fake-progressive NTSC scanning on most modern TV sets
 * http://people.ece.cornell.edu/land/courses/ece5760/video/gvworks/GV%27s%20works%20%20NTSC%20demystified%20-%20B&W%20Video%20and%20Sync%20-%20Part%201.htm
 * some code is duplicated for scanline timing adjustments to match for different code paths.
void vcnts(void) // each scan line interrupt, 262 total for scan lines and V sync
    uint8_t x;
    x = vfcounts & 0x7; // mask bits for port B bit line and bank selection
    if (x > 3) {
        DMASELECT = DMA_M;
        switch (x) {
        case 4:
            vml = SL_V4;
            DMAnSSA = (volatile uint24_t) vsyncu; // upper bitmap
            break;
        case 5:
            vml = SL_V3;
            break;
        case 6:
            vml = SL_V2;
            break;
        case 7:
            vml = SL_V1;
            DMAnSSA = (volatile uint24_t) vsync; // lower bitmap
            break;
        default:
            vml = SL_V_OFF;
            break;
    } else {
        DMASELECT = DMA_M;
        switch (x) {
        case 0:
            vml = SL_V4;
            break;
        case 1:
            vml = SL_V3;
            break;
        case 2:
            vml = SL_V2;
            break;
        case 3:
            vml = SL_V1;
            break;
        default:
            vml = SL_V_OFF;
            break;
    vfcounts++;
    switch (s_mode) {
    case sync0: // H sync and video, one line
        if (vfcounts >= B_COUNT) {
            s_mode = syncB;
            DMASELECT = DMA_M;
            DMAnSSZ = DMA_B;
            DMAnDSZ = DMAnSSZ;
            TRISB = SL_V_OFF;
             * trigger main task processing using the task manager
            task_hold = false; // clear idle routine run flag
            TMR4_Period8BitSet(TASK_S1);
            TMR4_StartTimer(); // run in main for timer 4 interrupt period then back to idle
        } else {
            if (vfcounts == scan_line) {
                TRISB = vml; // video memory line , on
            } else {
                TRISB = SL_V_OFF; // turn-off all video bits
        break;
    case sync1: // H sync and video, all lines
            s_mode = syncB;
            DMASELECT = DMA_M;
            DMAnSSZ = DMA_B;
            DMAnDSZ = DMAnSSZ;
        } else {
            if (ntsc_vid) {
            } else {
        break;
    case syncB: // H sync and no video, bottom blank
        if (vfcounts >= S_COUNT) {
            vfcounts = 0;
            s_mode = sync2;
            DMASELECT = DMA_M;
            DMAnSSA = (volatile uint24_t) & hsync;
            DMAnSSZ = DMA_B;
            DMAnDSZ = DMAnSSZ;
        break;
    case sync2: // V sync and no video
        if (vfcounts >= H_SYNC) {
            vfcounts = 0;
            s_mode = sync3;
            DMASELECT = DMA_M;
            DMAnSSZ = DMA_B;
            DMAnDSZ = DMAnSSZ;
            TMR4_Period8BitSet(TASK_S2);
        break;
    case sync3: // H sync and no video
        if (vfcounts >= H_COUNT) {
            vfcounts = 0;
            if ((bool) scan_line) {
                s_mode = sync0;
            } else {
                s_mode = sync1;
            DMASELECT = DMA_M;
            DMAnSSZ = DMA_B;
            DMAnDSZ = DMAnSSZ;
        break;
    default:
        vfcounts = 0;
        s_mode = sync1;
        DMASELECT = DMA_M;
        vbuf_ptr = vsync;
        DMAnSSZ = DMA_B;
        DMAnDSZ = DMAnSSZ;
        break;
     * re-trigger the state machine for a new scanline
Dadu@
Joined Feb 4, 2022
155
I have asked this question because it can clarify a lot of my basic understanding
I want to understand how fast microcontroller ( ATMEGA328P/PIC16F877A) can process data to required output.
Yes it is the game application. Why should not be run on device (ATMEGA328P/PIC16F877A). I found on internet that they don't have much speed and space. But still I don't see any article where they explain the calculation that show this microcontroller cannot used for game application
33,076
It depends entirely on what you are trying to do. The classic Pong game can be implemented in a PIC16C71 in which everything is done in software (the only other IC in the circuit is a voltage regulator), including processing the inputs and directly generating the video signal. That part only has 1 kword of ROM space and only 36 bytes of RAM. It quite impressive what can be done with very limited processing resources. But Pong is also not what people expect in a video game today.
It's really about game physics complexity, how closely it emulates some 'reality'. If the physics are a simple uniform pixel block/sprite mass X/Y trajectory, speed and rebound calculation that's doable with a few objects using simple 2D dot-matrix transformations in a sparse memory game board directly to scan display memory. Once you upgrade to complex polygons you start to need to split the pipeline into 2/3D image vector list processing and display compute scan conversion engines to transform coordinate systems. This is where the limitations of device speed and space start to bite even if you can generate display timing.
Read a few books on the subject like: https://www.amazon.com/Principles-Interactive-Computer-Graphics-McGraw-Hill/dp/0070463387
https://forum.allaboutcircuits.com/threads/led-matrix-animation.83063/post-591949
Dadu@
Joined Feb 4, 2022
155
I am interested to know more about this project. This is mainly because of how the PIC manages its resources and adjusts its timings.
I don't really want to develop this system but want to understand fundamental concepts how the PIC micro manages its resources ( CPU time, memory ) to generate video signal. It will be even better if you can explain something related to the clock cycle, processing time.
The controller simply implements a specific type of video processor. It's not a direct clock cycle, processing time relationship to video in general. You need to first understand conceptually how to make a simple video processor, then understand how to implement that on X hardware platform.
With each hardware platform there are fundamental speed and processing capabilities that limit what's possible.
From my PIC K43 NTSC demo:
Generating NTSC signals for simple games with a 8-bit controller is nothing new or novel but I wanted a way that was mainly independent from controller cpu processing limits. The transfer of 1 byte of SRAM (a C array) to a 1 byte SFR register (PORTB) is the hard dynamic signal resolution limit on this chip using DMA . That's about 100ns per signal transition with a 64MHz FOSC to the processor controlling a NSTC FSM (scanline state machine).
One pixel toggle.
Most of the basic hardware fundamentals are in this book. https://archive.org/details/tvtcb_doc
33,076
A PIC, especially a 16C series PIC, managing it's resources?
Now THAT'S funny!
With 36 bytes of RAM, there's not much memory management involved.
It was pure bit-banging.
The crystal was chosen so that a specific number of instruction cycles mapped to the necessary video signal elements. The analog signal was done using two outputs and a couple resistors to produce three different levels (white, black, and blacker-than-black).
Dadu@
Joined Feb 4, 2022
155
Now THAT'S funny!
I want to know basic about system like which deadline lines of system should be followed otherwise system will not give expected output.
At what time interval should the analog input be read?
How often should the display be updated?
Read that book in the link from my previous post first please.
