Video Booster layout to schematic circuit
AnalogKid
Joined Aug 1, 2013
12,265
With absolutely zero clue about what any of the parts are, you're asking a lot.
Also, isn't this backwards? How is it that you have a CAD layout without the schematic that created it?
ak
RPLaJeunesse
Joined Jul 29, 2018
264
It's possibly a 4-channel fully differential amplifier paired with a 3-terminal voltage regulator. Work with those descriptions and the pinouts used by the PCB to search for the part datasheets which will lead you to an application circuit. Good luck! (Or it is simply a protective diode array that requires a fixed clamp voltage supplied by the regulator? You tell me.)
schmitt trigger
Joined Jul 12, 2010
2,217
ak
Very likely…He may have copied the Gerber file and made an image with a Gerber viewer.
But as AK says, it is next to impossible, without at a bare minimum a BOM listing.
AnalogKid
Joined Aug 1, 2013
12,265
The chip has 4 channels and is differential in and out, so that severely limits the field. Still, without so much as the manufacturer's name I'm not gonna waste time surfing for it.
ak
