I am planning to use DMN2005 MOSFET in one of our designs. It is used at multiple places.
In one part of the circuit, it is used as part of simple inverter.
Drain is connected to a supply Vsc = Typ 12V, worst peak 15V with pull-up resister of 10K.
Source is GND. Gate has 1K pulldown and driven by controller which can output 3.3V or 0V.
Now my doubt,
The max Vgs will be 3.3V
max Vds will be 15V
Max Vgd will be -15V.
Whether the spec Max VGS /VGSS(for DMN2005 it is +/- 10V) from the datasheet can be used to verify Max VGD(-15V) in the circuit.
If we can't use that specification(VGSS/Max VGS), Is there any specification in the datasheet which can be used to check this VGD max in the circuit.
Now my doubt,
max Vds will be 15V
