Then your LED is open; ie: not conducting current. It may be connected backwards, or there may not be enough voltage across it to conduct. However, if Vref is 0v, then there is no current flow.Vref is measuring 0v with my LED
OK, then the problem is most likely that the regulator is not able to meet the regulation specifications at minimum current, which is 10mA. With such low current demand, you really should be using something like an LM317L, which has a minimum current specification of 5mA, maximum of 100mA. The problem with using the higher-rated LM317T is that you are at the ragged lower edge of what it can regulate, and the formula for calculating actual current is no longer accurate.Vref is measuring 1.3v with another UV LED
At a minimum, you should have a 10uF cap between your LM317's INPUT pin and ground. This helps a great deal to eliminate transients on the supply.My power supply is 12V I have no capacitors, but I tried my power stabilizer on 3 different power supplied 12V-14V and got 10mA 3.4V with my UV LED connected.
These are ceramic capacitors and only 1uF are you sure they will work?Well, I took a stab at it, and found these:
http://www.lemona.lt/index.php?page=item&i_id=84232
They are much smaller than what you were looking at. One or two of them would probably be enough.
Hmm, since I allready used the device to gather some data I can't really change anything or I will need to measure it all again form scratch.What is the voltage between the OUT and ADJ pins?
It should be right at 1.25v from your 8mA output report.
Now you can "fine tune" the current, if you wish.
For a given resistance:
Iout = 1.25/R1 (12.5 Ohms <= R1 <= 250)
For a given current:
R1 = 1.25/Iout (5mA <= Iout <= 100mA)
You are incorrect.HI
sgt Wookie is right , but you could use an LM1084 ,This has only 1.3 v drop, it still will not run to its full potential but it will run
