VeeCad libary
panic mode
Joined Oct 10, 2011
5,281
if using the latest version ( VeeCAD 2.46), i think the easiest way is to locate footprints library file V_Standard.per and doubleclick on it... it will show what is available as default.
you can use that instance of VeecAD as footprint buffet to copy and paste what you need to your project (in another instance).
if you are using KiCad to create schematics, just use those names as footprints then use menu File>Export>NetList>Orcad2
and in VeeCad import it (NetList>Import...)
then arrange parts and route board...
Homebrew1964
Joined Nov 22, 2024
289
Thanks Panic Mode.
panic mode
Joined Oct 10, 2011
5,281
you are welcome. or shall i say thank you. because i was unaware of this product until stumbling across your post. but it looked so straight forward that i spent 15min to learn more about it
Homebrew1964
Joined Nov 22, 2024
289
Mmmm, looks a lot easier to use than Fritzing, will go have a play :)
I'm currently laying out a circuit and i can say its more fun than using a pencil and graph paper, easier too when i can move components around without using an eraser and having smudge marks all over, i should have started with an easier circuit though :eek::oops:
Homebrew1964
Joined Nov 22, 2024
289
I just found footprints library file V_Standard.per and it's got tons of stuff
thanks again.
dl324
Joined Mar 30, 2015
18,472
I'm not a big fan of stripboard (Veroboard). The layout tends to be "clunky" due to the limitations of the tracked approach. Cutting tracks can also be tedious.
I prefer to do actual PCB layouts and making homemade boards.
You couldn't do something like this with Veroboard:
I used Eagle to do a board for a 4 discrete flip flop layout. I didn't want to wait for etching and drilling a board, so I used the board layout as a guide and did point-to-point wiring for a board that I modified on-the-fly to be 6 flip flops.
Maybe not even something like this:
35,193
You can take this one step further.
Get an affordable CNC engraver and have your PCB made in minutes.
dl324
Joined Mar 30, 2015
18,472
Probably the only reason to make a PCB is if your working with RF and you need a good earth plane.
There are many reasons for making PCBs for designs that aren't RF. I have several Veroboards and have never considered using them due to the layout restrictions. I'm much more inclined to use pad per hole phenolic boards for quick and dirty circuits. If I plan to make more than one, it's almost always a custom board layout. Single sided, so no ground planes.
