VCCS Analysis
tAllann
Joined Oct 26, 2013
11
I solved for Vo in terms of Vi and I get the negative of the correct answer according to the book. Someone told me that the TA set the node to the left of Vo = to -Vo, and this explains why my answer is the negative, but I don't understand why the node adjacent to Vo is -Vo instead of just Vo.
In this problem, gm = 2m / 1 ohm, and I get that Vo = -2 Vi, but the book gets that V0 = 2 Vi.
33,218
gm = 2m/Ω = 2mA/V
Vo = -(gm*Vx)*2kΩ
Vx = Vi/2
Vo = -((2m/Ω)*(Vi/2))*2kΩ
Vo = -2Vi
You're right, they're wrong.
I have NO idea why they are putting Vo on the top-right node of the left hand circuit (that's what you are talking about, right?).
LvW
Joined Jun 13, 2013
2,037
tAllan,
the circuit shown equals the classical equivalent small-signal ac circuit diagram for a common emitter transistor amplifier. As you will know, this amplifier has inverting gain characteristics.
Thus, for a positive input voltage, the output is negative, indeed.
tAllann
Joined Oct 26, 2013
11
tAllan,
But can't you solve the circuit without knowing this with simple analysis? Is my analysis wrong?
33,218
Of course you can solve it without relying on this. You did. I did.
He is just pointing out that this is a circuit that happens to match a common circuit that you will run into and, if you DID happen to know that, that it confirms that the output voltage is inverted relative to the input voltage.
