MisterBill2
- Joined Jan 23, 2018
- 28,307
The very simple thing will be to apply a known voltage to the input and observe the number of counts that register. I hope that you are able to see actual counts before scaling is applied. One interesting fact is that the reference voltage is NOT the same as the full scale voltage, at least for many A/D converters. While the reference is 2.531 for some devices, the input range is zero to ten volts. At least for those in the reference book from Motorola. So there goes one theory! Certainly there should be some information about the analog input voltage range for the board you are using. ALL of the analog inputs to A/D conversions that I have used have nice inputs like 0 to 10 or zero to 5 volts. So there is another piece of information that is rather important to have.
