Variable PSU not producing wanted results
ChickenMcDo
Joined Jun 4, 2022
Would like to ask help why my circuit is not working? In the first one, the capacitor is exploding and it produces very small results. For the second one, the capacitor also explodes and doesn't produce the needed results.
The needed results are from 0 to 12 volts. Both use a 12V, 1A transformer. 1654364044298.png1654364031100.png
k1ng 1337
Joined Sep 11, 2020
1,038
In the first schematic there is a short circuit from the D2 / D3 / C1 node to the transformer. In the second schematic there is another short circuit from the D3 / D4 node to ground.
Edit: Is C1 in the second schematic a wire or capacitor? It has the name but looks like a wire. R3 is connected to ground on both sides and there is a seemingly misplaced node nearby.
dl324
Joined Mar 30, 2015
18,453
Welcome to AAC!
The bridge rectifier and capacitor connections are wrong.
Schematic is too messy. Will analyze later (maybe).
Are things blowing up in the simulator?
Next time, print to PDF and take a clip so we don't have to deal with the grid or meaningless colors.
KeithWalker
Joined Jul 10, 2017
3,615
The layout of your circuit diagram makes it very difficult to follow. Have a look on-line at how other linear regulated power supply circuits are drawn and try to simplify yours..
What is the voltage rating of the capacitor? When the circuit is wired correctly there will be approximately 16V across it, It should be rated for at least 25VDC,
