van battery inverters 240v or less?
jonnyb333
Joined Nov 19, 2017
hi there
I know nothing about electronics and would like some expert help please. I have a ford transit connect van and use it when I fly my drones. I need to re-charge the drone batteries on site and have looked at the possibility of installing a separate battery and inverter. My stumbling block is do I set the voltage to 240v? All the chargers I have, come with transformers as I imagine they are designed originally for the American market.
My thought is to by-pass the transformers (on the battery chargers and macbook) using a voltage that can deliver 17.5v at between 2 and 5.72a, 26.3v 3.83A 100w and 20v 4.25a. is this possible? or is it safer, more flexible and even possible by the 240v method? To a novice like me it seems odd to take 115v up to 240v to bring it back down again. but what do I know?
please help!
Keep it safe by using a step up/down transformer to deliver the needed AC voltages for the chargers from the inverter if it can't supply the correct AC voltage.
