- Joined Jan 23, 2018
- 28,353
The good news is that now you understand how to be able to use the motor for your different sort of application. Glad I was able to offer a bit of help.
Mine is an area on its own, and feeds the shop as well as the house all separate areas.As for using a shop vac - that sucker is huge. And noisy as all get-go. Getting away from that large noisy machine will add to the pleasure of woodcrafting.
I do a lot of grinding of weldments with an angle grinders, I also wear glasses. I hate the normal face shields since they are always sliding off when I bend over so I bought a full face paintball mask. They work great to keep stuff out of your face when grinding or in this case cutting. They make a mask just like it for the job but they are ~$100 at the welding store and are rated the same by ANSI.Safety glasses are not enough when your face is getting showered with fiberglass.
I think that the main difference is that the emissions air pump utilizes a centrifugal separator, the notches in the back side of the drive pulley, to keep stuff out, and so it lacks any inlet connection. And at one time they were able to be redirected to inflate jeep tires. I think that they were capable of 30PSI., no idea about the flow rate though.Incidentally, for cutting fiberglass, I'd use a diamond blade on an angle grinder. LOTS of glass dust though. Respirator is mandatory as well as a good face shield. Safety glasses are not enough when your face is getting showered with fiberglass.
I actually have a few fiberglass spun tanks from water softeners. They're rated at 200 PSI so I use them as an extra reservoir for my air compressor. Those times when I'm blowing out sprinklers for the winter it comes in handy because my 4 gallon compressor isn't enough to blow down the sprinklers. Three tanks actually. Had to use some electrical ABS conduit fittings to get down to a usable size. Then standard gas pipe for air fittings.
Actually, I mentioned my smog pump. I'm resisting the urge to post a new thread regarding PWM and motor speed control. I know the basics on how to do it. I have an old light dimmer from my wife's Celica (she wrecked). It's PWM. But I am confident it can't handle the power. So I'm planning on using a power MOSFET to handle the speed control for the smog pump motor. I have yet to mess with it. I only know the pump works. It's actually a lot like a vacuum pump, only its output is pumped into the exhaust manifold. But we'll get there this fall.
OK, your pumps are quite different. I was talking about the ones from the seventies Mopar vehicles. I guess thyt things have changed a bit.The smog pump on my Toyota Taco(ma) is electric. So is the one I pulled from the BMW in the junk yard. On full power it blows some serious air through (guessing) about a 7/8 inch opening. It has about a 1 inch inlet opening as well. I'd definitely want to throttle it back when giving oxygen (ambient air) to a fireplace fire: or to heat exchanger tubes within a fireplace. Great thing about it is if there's a power failure in the winter I still have the fireplace. The smog pump is 12 volt driven and I have a couple spare 12 volt batteries in the garage that came out of wrecked cars. One is currently held at 13.6 volts and plays a car radio. The other one - I pull it down from time to time and boost the charge on it just to keep it fresh should I ever have need for 12 volts. Thinking about it - I should grab some 12 volt LED car tail lamps for ambient lighting should power go out and I'm left in the dark. Oh, wait a minute, I'm always in the dark.
Don't know if I mentioned it - I have the dash light dimmer circuit out of a Celica. It's a PWM module. Planning (in my mind) to use that to drive an N type MOSFET to control the speed of the motor. Later this year I'll dink with it and see if I can get it to do what I want. The FET I have is a pretty robust FET. Out of a motor controller from a hot tub. If I recall the data sheet it said it was good for 600 volts. It will be interesting to see if it will work on 12 volts.
Where would I be able to purchase a Johnson U-9840 motorAfter cleaning tons of dust off the motor I found it's a Johnson Universal motor, number U-9820. Best I can find is U-9835 and U-9840. The data sheet for the 35 is interesting but it says nothing about a center tapped winding. Oh well. Anyway, thanks for all the help.
| Thread starter | Similar threads | Forum | Replies | Date |
| R | Vacuum brush motor quit | General Electronics Chat | 17 | |
| K | Which element on the card is the fuse? | General Electronics Chat | 7 | |
Control Dyson DC35 Multifloor vacuum cleaner motor | Automation, Robotics & Control | 106 | |
| W | Brush motor for shark vacuum | Technical Repair | 19 | |
Wiring of a vacuum cleaner motor | Technical Repair | 10 |
