UVC Light Bulb Gets Smoking Hot Only in certain outlets.
KMoffett
Joined Dec 19, 2007
2,918
Sunday and no answer from the OP. If this is in North America, and the voltages at different outlets is significantly different, it could be a bad Neutral connection. This happened at my families old farm house. Bulbs in certain rooms had extremely short lives. Turned out it was a loose Neutral at the pole. Dad saw it arcing during a wind storm. REC fixed that and no more problems.
28,272
I certainly recommend checking the voltage to the lamp, because that is indeed important, and there could be a problem.
And I note that there has been no mention as to the actual type of bulb, mercury vapor or otherwise. And that matters as well.
Tonyr1084
Joined Sep 24, 2015
9,744
Please note the TS has not visited or commented on this thread since post #1. Post #22 was in January, so the TS has obviously fixed or forgotten about the problem.
