using timer 2 on atmega328
MacIntoshCZ
Joined Sep 4, 2019
22
Hello there,
i would like use timer 2 on avr, but i probably made somewhere a mistake or avr is faulty becouse i am getting square wave about 95%duty cycle.
I already succesfully used timer 0.
I should get 100Khz square wave, 50% duty cycle, on pin 11. Thanks for help
Here is code:
void setup() {
TCCR2A = 0;
TCCR2B = 0;
TCNT2 = 0;
TCCR2A |= (1 << WGM20) | (1 << WGM21);
TCCR2B |= (1 << WGM22);
TIMSK2 |= 1;
TCCR2A |= (1 << COM2A1);
TCCR2A |= (1 << COM2B1);
OCR2A |= 160;
OCR2B |= 80;
pinMode(3, OUTPUT);
pinMode(11, OUTPUT);
TCCR2B |= (1 << CS20);
interrupts();
void loop() {
MacIntoshCZ
Joined Sep 4, 2019
22
That doesn't look like a complete program.
Where is your main( ) code?
There is no code needed in main function. Actually its from ArduinoIDE, so function main() is function loop(). But in my case there should be phase shifting. Becouse i want to delay other timers by 1/3 of period between each
34,814
Sorry. You are right. Goes to show that I don't do Arduino.
BobaMosfet
Joined Jul 1, 2009
2,211
I would recommend reading the datasheet and doing so until you understand it. Atmel datasheets are written really well, and usually provide a step-by-step walking through of how to use a feature (even to the point of providing C & assembly language examples in some cases).
MacIntoshCZ
Joined Sep 4, 2019
22
I already solve the problem. There was no mistake in my code. Atmega was just faulty.
