There is a trend to use smart plugs as a dimmer with things it, at least to my understanding, shouldn't dim.
These smart plugs work on the AC side and will dim leds that are designed to be dimmed on the ac side.
Apparently some found that they also dim constant current drivers .. on the ac side.
Makes no sense to me but I'm less than a rookie here.
My limited understanding that the smart plugs do some work using null crossing point on the ac side.
It also seems to me that this will basically shut the constant current driver off on the ac side.. at what 60-ish Hz?
Doesn't seem like a smart way to go.
https://www.reef2reef.com/threads/want-to-supplement-my-radion-blues-with-white-light.1047635/page-3
See #54 for the plug that "dims" a Constant current driver.
