Using resistors to safely discharge a 48v 20Ah battery pack
Lumenosity
Joined Mar 1, 2017
614
Good day friends,
Todays world of electronics finds me with a 48v, 20Ah LiFEPO4 battery pack for an electric bicycle which is a 16 cell pack which can charge to 3.65v per cell
I am trying to find a way to safely discharge that battery pack from full charge of 58.4v down to it's internally controlled BMS cut off voltage of 40v at 20Amps while using a PEMZ-15 or other battery / current monitoring device to measure the amount of energy withdrawn from that battery pack.
If I had a 48v inverter I would simply use that and an adequate load, but I do not have one.
I'm not sure if resistors, a shunt or something else would be best for this? Maybe 10 x 100watt light bulbs or some other load measured to draw 1168watts?
I don't want to lose that battery energy to heat without first measuring it during this discharge test. so I assume the resistors would be placed after the measuring device? But then, I'm not sure the measuring device can handle that much power either.
Since the pack starts out at it's full voltage, I will use that for the initial calculation
Watts = Amps x Voltage
Watts = 20A x 58.4v
Watts = 1,168
So I need to dissipate 1,168 watts (initially, since the voltage will drop constantly during the discharge)
I'm just not sure how to do it safely.
Thanks
Ian0
Joined Aug 7, 2020
13,283
Lamps are a pretty good way of doing it, but filament lamps are getting quite rare these days, especially 48V ones. 5 sets of four 55W 12V headlight lamps in series/parallel would probably be the easiest.
Resistors would need heatsinks.
Do you know anyone who tests audio amplifiers who could lend you a 4Ω 1kW dummy load?
With fixed resistors the only equipment you need is a multimeter and a clock. Using lamps, the resistance varies with voltage, meaning that you really need an ammeter as well.
Lumenosity
Joined Mar 1, 2017
614
I decided obtaining all those headlamps wouldn't be feasible.
I decided to just go ahead and purchase a 48v Inverter.
Now I can also use this battery for emergency power so it's good.
Thanks, good information and I will keep that in mind for future projects.
Lumenosity
Joined Mar 1, 2017
614
Someone on another forum suggested I use several of those old coiled ring burners from an old stove top.
That seems like a good suggestion if I weren't getting a 48v inverter.
Also, found out today that 48v can indeed give you a little twing if you're not careful.
