Using op-amp to convert from current to voltage
Dritech
Joined Sep 21, 2011
907
Hi all,
I need to convert 4 to 20mA to 0 to 10V using an op-amp. When web searching I found Current to Voltage op-amps like the one in the link below:
https://upload.wikimedia.org/wikipedia/commons/e/ee/Current_Voltage_Converter.svg
Why are all the current to voltage converter circuit inverting? Can it be used in a non-inverting setup?
Also, if I use a 500ohms resistor I will get 10V for a 20mA input but 2V for 4mA input current. Is there a way to scale the output from 2V to 10V to 0V to 10V without using an MCU?
Thanks in advance.
ericgibbs
Joined Jan 29, 2010
21,543
Is it fair to ground one end of the current sensing resistor?
hi Mike,
Its common practice to connect the bottom end of the Loop load resistor to 0V at the OPA end.
Never had a problem doing it this way in a number of marine applications.
Do you have an alternative method.?
Eric
MikeML
5,444
I always thought that the receiver for a 20mA loop should have a differential input with a relatively high common-mode capability?
Can you have two or more receivers in a loop or is there always only one?
Alec_t
Joined Sep 17, 2013
15,150
Presumably if you had 2 receivers then one could ground its sense resistor but the other would consequently have to use a differential input?
ericgibbs
Joined Jan 29, 2010
21,543
hi,
The marine Tidal Height products I designed and manufactured used a single immersed water pressure sensor, connected via a twin screened cable, with a internal atmospheric air vent pipe.
The immersed sensor was powered via the same cable, with 12Vdc thru 24Vdc, the sensor modulated the loop current drawn by the sensor, from 4mA thru 20mA which was proportional to the Tidal height [immersed water depth].
Eric
added 'single'
Dritech
Joined Sep 21, 2011
907
Is it possible to post a screenshot of the circuit please?
I downloaded the software but some of the components are not showing. Thanks.
Roderick Young
Joined Feb 22, 2015
408
Not to overly complicate things, but if you want it to be truly independent of voltage, you can use a high linearity optoisolator at the input. They're like 25 to 50 cents, and have a current output proportional to the current input, very good for the range of current you're considering (20 mA).
