Hello, skip to bottom paragraph for question
For my intro to electronics class I have to make a clock using a logic circuit. I'm sure some of you have seen posts about it before, it appears to be a common project for early electrical engineer students.
While I may need help with the circuit in the future, my first question is more of how to make a much more exciting logic clock using Nixie Tubes instead of boring old 7-segment displays. There are a ton of nixie tubes I've been looking at, I can't quite seem to find which one would be the best looking.. If you happen to have any suggestions on what you personally would think would look the best I would love to know
Preferrably between 10-20 dollars per tube. They have gotten expensive!
I found this site but it's half german. Atleast it gives me a good list of possible tubes: http://www.tube-tester.com/sites/nixie/trade01-nixie-tubes.htm
So now there real question: How does one go about setting up one of these tubes compared to a simple 7segment LED. Primarily because VFD (vacuum flourescent displays) use much more voltage (around 60v's). Nixies take about 170 volts.. Which I'm not 100% sure how I would set up a booster for that. Which leaves me wondering if the clock pulse on them should be that high or is there a heater terminal on them that will take a constant 60v/170v and wait for the 5v pulse from my logic circuit.
My circuit is running off of 5 volts, and was thinking of boosting the voltage with something like this:
Adapted to 170vdc if I use nixie, which I most likely will. I hope this all makes sense. A quick recap on the question at hand, How in tarnation can I setup nixie tubes as my display for a logic clock with a 5 volt power supply. Am I on the right track? How might I change the above circuit to step up 170vdc from 5vdc?(just a bigger inductor?)
Thank you for reading!
