Hey guys, long time lurker, first post.
I've been following a design to make a colour organ, this one specifically : http://makezineblog.files.wordpress.com/2010/10/ledcolororgan-schem_r2.gif and it works great (I used different op-amps and 2n2222 transistors) when powering a couple LEDs.
What I would like to do is change the output, so instead of 2 LEDS, I will connect a whole 5m LED strip such as this one http://www.adafruit.com/products/285 for this I will need a bigger power transistor / MOSFET. I decided to give designing in a MOSFET a go as I would like to learn and I thought it would be beneficial in minimising power consumption (compared to a transistor) especially when used on multiple channels.
To accomodate the MOSFET (I'm using a FQP30N06, threshold volt. ~2v -> 4v) I've made the voltage reach 3v to safely turn on the MOSFET thereby switching on the lights when it reaches the required audio level, I achieved this by modifying the active filter to have a gain of 2.5 and changing the resistor connected to the gate from a 100k to a larger value ~820K.
After all this, the light is turning on and reacts to sound as expected (I am still testing with only a couple LEDs as I don't have the strip yet) but it is giving a different effect. With the transistor the colour of the LED would go through the spectrum of dim to very bright according to sound level. While the MOSFET is either hard on or hard off, this looks like it's in saturation,
I'm just hoping someone would be able to help me and point me in the right direction as to how I can achieve a dim to very bright effect using the MOSFET? (correct me if I'm wrong, but I need to get it operating in it's Triode region and how would I go about this? or are MOSFETs not able to give the same effect?)
Thanks in advance!
Thanks in advance!
