Using Ht12e , ht12d is it suitable nowadays to control high power leds
samerelec
Joined May 15, 2023
7
Hi to all
Ht12e and 12d is a simple way to wireless cotrolling leds ihave 2 questions:
First Are they still the easy and effficient option analogue cotroll otherwise what else.
Second question is when i connect them to led and press button it turns on after i realse it turns off, what to connect to make a single press turn the led on and keep so when i release my press...then make another press to turn led off.
Many thanks
sghioto
Joined Dec 31, 2017
8,763
Normally those ready made modules use a microprocessor to control multiple functions. It can be done with analalog but the micro would be simpler.
sghioto
Joined Dec 31, 2017
8,763
One way is to use a second switch for the OFF mode using a set-reset circuit.
Showing a 555 set-reset circuit with a negative input from the ht12d.
Output of 555 can drive a N mosfet for high current LEDs.
samerelec
Joined May 15, 2023
7
Dear sghioto, i am connecting a led that uses at least 1.05 amp and 3v ... actually i haven't been successful with mosfets to increase the current to my led which gave me great depression to achieve success.
If you have an idea on how to make greater current to led using mosfet withh 555 i would be thankfull for you to explain
Many thanks
sghioto
Joined Dec 31, 2017
8,763
The value for R1 depends on the voltage supply Vcc. A vast number of high current N channel mosfets are available for Q1.
What is the supply voltage Vcc?
bidrohini
Joined Jul 29, 2022
190
You have to make a latch switch. I can see you have already started working with 555. Another option is to use a J-K flip flop(apart from using a micrcontroller).
