Using CODE Tags
djsfantasi
Joined Apr 11, 2010
9,237
A common mistake many members make is pasting their code into their post without properly formatting it. Especially when the program is long, this makes the entire post difficult to read and it is easy to lose track of the poster’s comments.
Fortunately, there is a simple way to eliminate this problem. Someone may have mentioned code tags.
This excerpt from the Help pages under “BB codes” introduces the method.
[CODE] - Programming Code Display
Displays text in one of several programming languages, highlighting the syntax where possible.
Example:General code:
[CODE]General
code[/CODE]
The easiest way to include a code tag is to use the menu. Click on the three dots on the menu bar (on my system, they are in the upper left). A drop-down menu appears and you should click on “</> Code”.
There are several fields on the resulting page which are optional except the text block at the bottom. This is where you paste your program code. The other field I may use occasionally is “Language:”, which appropriately formats your code based on its language.
Hope you find this useful next time you are posting your program code.
KeithWalker
Joined Jul 10, 2017
3,619
I wondered how to present programs correctly in this forum. Thank you for the information. The following is my first use of code tags, just to see how it works:
Code:
/* Handshaking between two arduinos.
   Connect 9 on one to 10 on the other and vica-versa
   Which ever one completes its loop first will wait for the other to finish
   before they both start again.
void setup() {
  pinMode(9, INPUT);
  pinMode(10, OUTPUT);
  digitalWrite(10, LOW);
  pinMode(13, OUTPUT);
  int i ;
void loop() {
    digitalWrite(10, HIGH);
    while (digitalRead(9) == (LOW));// Wait until 9 goes HIGH
    delay (10);
  // Blink 6 times
  for(i = 0; i < 6; i++)
  {digitalWrite(13, HIGH);
  delay(500);
  digitalWrite(13, LOW);
  delay(500); }
35,187
If you ever need to demonstrate to someone how to use code tags such as in this example:
[code] ... your code goes here ... [/code]
enclose your demo with plain tags:
[plain][code] ... your code goes here ... [/code][/plain]
djsfantasi
Joined Apr 11, 2010
9,237
I’ve been trying to figure that out! Thanks. I’m editing my original post.
UPDATE: Didn’t work for me. I tried before and inside the QUOTE tag.
35,187
I cannot see what you tried.
Just so that I can see what you are doing, use ( ) braces instead:
(plain)(code) ... your code goes here ... (/code)(/plain)
djsfantasi
Joined Apr 11, 2010
9,237
I tried two different ways. First:
{QUOTE}{CODE} - Programming Code Display
{plain}{CODE}General
code{/CODE}{/plain}
{/QUOTE}
And then (and didn’t expect this to work. I was right):
{plain}{QUOTE}QUOTE}{CODE} - Programming Code Display
code{/CODE}
{/QUOTE}{/plain}
Note the first code tag was cut & pasted from the Help page.
KeithWalker
Joined Jul 10, 2017
3,619
To get it to work, I just opened an old arduino program, copied the contents and pasted it into the code area right after the "1" line number.
MaxHeadRoom
Joined Jul 18, 2013
30,813
Using Assembly.
[CODE = nasm
Netwide Assembler:
Set_PPS2
        banksel RA1PPS
        movlw   0x02
;        movwf   RA1PPS
        return
dly_2
; Delay = 2 seconds
        movlw    0x03
        movwf    d1
        movlw    0x18
        movwf    d2
        movlw    0x02
        return
WBahn
Joined Mar 31, 2012
33,203
There are several languages for which syntax highlighting is supported. C, javascript, assembly, and a few others. I've never been able to find a list. The Help topic here is out of date in this (and many) regards.
You can also put code snippets, such as x = sqrt(y);, inline by using [ICODE]x = sqrt(y);[/ICODE]
Ya’akov
Joined Jan 27, 2019
10,300
Hey, @djsfantasi—I edited your post to use [PLAIN] tags like this:
[QUOTE]
[PLAIN]​
[CODE] - Programming Code Display​
Displays text in one of several programming languages, highlighting the syntax where possible.​
Example: General code:​
[CODE]General code[/CODE]​
[/PLAIN]​
[/QUOTE]
The indentation is to make it more readable. You probably don't want to know the tag gymnastics I went through to get that to display correctly. Let's just say it wasn't easy.
35,187
In essence, this has drifted way off topic from the original intent of the thread.
The primary intent was to show how to embed programming code between opening and closing code tags.
[code] ... your program code ... [/code]
The secondary post was how to show the above example without actually invoking the code tags by embedding in between plain tags.
[plain][code] ... your program code ... [/code][/plain]
Let's leave it at that.
35,187
On another note, we often use the variable i as the index of an array.
This becomes interpreted as the italics tag by the BBcode analyzer. You will have to use a different variable when indexing arrays and don't use any other variable such as b, u, s that would be considered another format tag.
