Regarding this simple SMPS, is it possible to replace the MOSFET with a high-voltage BJT? Perhaps with some sacrifice in efficiency/power (which I am not too worried about)?
Have you ever built a SMPS and then changed MOSFET to BJT?Since the BJT is less efficient and thus will dissipate more heat, it may need a larger heat sink than the MOSFET.
Interesting... I have a BUL216 that I was going to try.With some consideration, yes. You have to consider the recovery time from saturation.
The storage time is the delay between the shut-off of the base current and the point at which the collector current starts to turn off. The fall time is the time it takes for the collector current to return to zero. Thus the total turn off time for the transistor would be 3.6μs. This, of course, limits that maximum switching frequency for the device. This is one of the reasons MOSFETs are often preferred for switching applications, since they have no storage time delay and also have a faster fall time.Interesting... I have a BUL216 that I was going to try.
It quotes a storage time of 3us, and fall time 600ns, with 200uH inductive load. Was do these times refer to, exactly?
The thread is discussing the transistor in a DC switching power supply with no transformer. I don't understand your comment. Did you post in the wrong thread?A small transformer maybe would be better, since you don't need high voltage rating.
Have you ever built any small SMPS?The thread is discussing the transistor in a DC switching power supply with no transformer. I don't understand your comment. Did you post in the wrong thread?![]()
My answers are above in blue.Have you ever built any small SMPS? I designed a 1A, 15V to 5V buck converter for a civilian space application. It used an inductor. Do you consider that small?
1. There might be a heatsink or not. True.
2. They often use transformers. True. And they often use inductors if they don't need isolation.
3. There is no information that a transformer can not be used. True.
And, why not change it to have a transformer? Why would you? The op's question was about substituting a BJT for a MOSFET in a circuit he already has. That seems to be only slightly related to whether an inductor or a transformer is used for the voltage conversion.
Did I post in the wrong thread? Only you can answer that.
May I ask you what you mean by larger heatsink? A heatsink that can dissipate more power for a given temperature rise.
