Using An Electret Microphone
DickCappels
Joined Aug 21, 2008
10,661
You should connect it as follows:
You will have to experiment to find which lead is ground.
In my limited experience the load resistor (RL)should be between 3.3k and 4.7k. Just make sure than when everything is connected and powered-up that there is at least 500 millivolts across RL.
Vs should be 12 volts or below. It would be better if you could buy one with specifications available, but these are not so hard to use.
Ian0
Joined Aug 7, 2020
13,267
If you look carefully at the pcb to which the pins attach, then there are usually some tracks which make contact with the case. That side is ground.
