Using A Triac OptoIsolator for DC-DC Switching
Keenan Rebera
Joined Apr 8, 2018
Hi all. I grabbed the wrong optoisolator.
I was looking for a 4N25 but instead grabbed a MOC3052 Triac that is typically used to have a DC circuit control a high-voltage AC line.
Is there any way I can switch a high voltage DC circuit with this? Slap on a diode to rectify or something?
TeeKay6
Joined Apr 20, 2019
573
@Keenan Rebera
Update. Deleted as info was erroneous.
38,751
The triac doesn't care whether it is switching AC or DC. Assuming that all other specs are okay for your application, then yes, you can certainly switch a DC voltage on/off.
A triac may not care whether it's AC or DC to turn on but it certainly does to turn off.
The current needs to go to zero for the triac to turn off so it will turn off fine with AC, but not with DC.
So, sorry, you cannot use the triac opto to switch DC, you need a DC type such as the 4N25. :mad:
TeeKay6
Joined Apr 20, 2019
573
@crutschow @Keenan Rebera
I agree completely with Crutschow. As I was preparing for sleep my brain finally awoke and I rushed here only to find that Crutschow had beat me to it! Thanks!
Keenan Rebera
Joined Apr 8, 2018
The DC circuit was 48 volts but it’s alright! I found a DC one on an old scoreboard circuit from the 1990’s I had sitting in my closet
