I've seen the data sheets as it relates to the arduino but since I'm not using that I wanted to see the protocol for the rc522 itself. Like the commands it requires for writing to a tag. When to use the reset and other pins. Clocking pin, etc. can't seem to find any of that.Hello,
You only need the datasheet of the PIC you will use and the datasheet of the RFID-RC522.
The communication protocol is the SPI so check the proper section on PIC datasheet.
Here you have a RFID-RC522 tutorial (just found now), based on arduino. Perhaps it's useful for RFID-RC522 pinout.
simozz
This is the MFRC522 datasheet that you need. Note that following the links from the PDF linked in #2 you could reach it.jwells02 said:I wanted to see the protocol for the rc522 itself. Like the commands it requires for writing to a tag. When to use the reset and other pins. Clocking pin, etc. can't seem to find any of that.
