I am trying to make a cooling system for my high end PC, but instead of the traditional air and water coolers, I wanted to go with sub-zero cooling. I do not want to use LN2 as it is expensive and not a relatively long term solution.
I was thinking, I should but a Mini-Split Ductless AC unit and instead of connecting the outdoor compressor-condenser unit to the evaporator unit that would be placed in the room that needed to be cooled, I would instead connect the copper tubes from the outdoor compressor unit to a metal CPU block. I have the Heat-killer IV Pro CPU block which has a full metal construction and was thinking it should be able to withstand the immense pressures of the system. I would solder connect the copper tubing to the CPU block and the other end of the tubing would be connected to the compressor unit and would be sealed.
This is the my basic view of the path that the refrigerant would take:
Compressor --> Condenser --> Expansion Valve --> CPU Block (instead of evaporator) --> Compressor
The reason i need help is because I know that the compressor unit comes pre-charged with the amount of refrigerant needed for the AC to run normally using compressor unit and the evaporator unit that comes with the mini-split system. I wanted to know what i needed to change so that it works with the cpu block instead of with a evaporator unit because the evaporator unit has a bigger volume for the refrigerant than the CPU block and i needed to know what i would need to adjust. Also I need to know how the refrigerant would behave inside the CPU block because in think that inside the evaporator unit, the refrigerant enters as a cold liquid and evaporates carrying the heat away as a gas. When it is replaced with a CPU block i needed to know if the heat of the CPU is enough for it to turn that liquid into a gas and what would happen if not.
I am comfortable modifying the pressures of the refrigerants, voltages for the compressor unit, lengths of tubing, and other things that don't involve replacing parts of the mini-split AC system.
ANY HELP IS APPRECIATED
