Using SIM900A MINI V3.8.2 Module with ESP32
zazas321
Joined Nov 29, 2015
936
Hello. I plan to use this module with my ESP32. I have received this module and I am slightly confused regarding selecting the right jumper combination for my needs:
The module used:
https://www.ebay.com/itm/MINI-V3-8-...on-Module-GSM-GPRS-SIM900A-Good-/281743836908
I have also found some simmilar guides such as :
I am mainly concerned about the jumpers marked in red circle:
However, on my board, the names of the headers are slightly different also, I am not sure what are they used for. Are they for switching between 5V and 3.3V logic?
Following is the picture of my module headers:
In my case, ESP32 is 3.3V logic. Do I need to connect these jumpers in any way ? Thanks in advance
Ya’akov
Joined Jan 27, 2019
10,295
The 3VR and 3VT seem to be 3V receive and transmit pins, respectively, no jumpers.
It seems to be a revision providing with 3.3 and 5V at the same time.
zazas321
Joined Nov 29, 2015
936
Hm. Okay. So I want to connect these 3VR and 3VT to my ESP32 rx tx?
At first, I thought that serial RX and TX on the sim module will be located here: (See top of the picture for 3 pin header)
It says OBS-2 and GND. I cannot figure out what is OBS-2.
However, looking at other similar modules such as :
You can see that they say that the 3 pin header as shown in my previous image have TX/RX and GND. And also they say something about those jumpers, apparently, they need to be connected in this strange manner
Moderators note : cropped image
Ya’akov
Joined Jan 27, 2019
10,295
From everything I can find, I am convinced that you need to connect the MCU to the 3VR/T pins.
