Using a crystal to regulate a PIC error
camerart
Joined Feb 25, 2013
3,853
I use crystals to regulate PICs.
If the crystal has 'say' a possible error of 20PPM, how many seconds/milliseconds could it error in 1Hr.
Camerart.
35,191
There are 3600 seconds in 1 hour, or 3,600,000 milliseconds in 1 hour.
Thus 1 ppm is equivalent to 3.6 milliseconds in 1 hour
20 ppm is 72 milliseconds in 1 hour.
btw, crystals can be trimmed by adjusting the load capacitors on the crystal.
Watch crystals are designed to have a resonant frequency slightly higher than the nominal 32768Hz frequency. Adding trim capacitors will allow one to bring the frequency down closer match the desired frequency.
camerart
Joined Feb 25, 2013
3,853
Hi Mc and I,
Excellent answers, thanks.
This means that, what I am trying to figure out, which is a GPS synchronisation, is feasable, if needed.
I've been trying to work it out for hours :)
Thanks,
C.
jaack
Joined Sep 13, 2013
Many times the ppm specs for quartz crystals for oscillator control vary with their temperature and should be part of the spec. Maybe you have an incomplete spec. i.e, 20 ppm/degree Cent.
When the oscillator circuitry heats up, the crystal's frequency varies. To get a precision oscillator, the crystal will put into a tiny oven or a precision-isolated heat source. The heat keeps a constant temperature of the crystal's structure ensuring stable frequency.
See this link for more details https://www.everythingrf.com/community/tcxo-vs-ocxo
camerart
Joined Feb 25, 2013
3,853
Hi J,
I have 2x options, for the project I'm working on, and needed a ball park figure, to help me compare both.
Thanks for the temp info, but it pobably won't be needed, as I've chosen the 'other' option to try first, but could use 10PPM, crystals or a temp controller.
Thanks, C.
