Using a 555 timer to generate an audio signal
hach10
Joined Feb 20, 2019
So i am working on a circuits project and i could use some help. The requirements are below and the schematic we need to use is attached. I am just having a hard time starting the project. I need to be able to calculate the values for this circuit to work and any help would be great.
Students need to provide an audio signal that is a function of the light level. Here, a 555 timer is to be used as a voltage controlled oscillator (VCO) that will generate a tone at a frequency of 500 Hz (+/-20%) at zero light level and 1000 Hz at full light (0 volts applied to motor). A small speaker or headset can be used to make the output audible and an oscilloscope can be used to verify the frequencies. One possible circuit is provided in the project data sheets folder (555CVCO.ASC) which can be used as a starting point. The 555 timer should have a frequency range from (~500Hz to ~1500Hz). The schematic below is for the 555 timer.
SamR
Joined Mar 19, 2019
5,542
What is your light sensor? Measure its output to find it's V range? Set the timing resistor and capacitor to cover the output freq. range based on the input values. Use a 555 timer calculator to help find the resistor and cap values.
dl324
Joined Mar 30, 2015
18,478
Does this imply that this is school work?
