using a 1.5v kitchen timer to turn on a 2n5064 scr at 9v
dave321
Joined Dec 10, 2010
65
0.1VDC, AC, peak-to-peak, or RMS?
What meter setting did you use? Or was that measured on an oscilloscope?
just on a cheap dmm voltage setting.it was going up and down, just like the currentwas all over ther place,
so probably peak to peak ?
dave321
Joined Dec 10, 2010
65
I am sceptical.
Why not turn the device on and off manually with a switch?
Use the kitchen timer or any other timing device.
i want to turn things on after a set time.
i would have thought it was simple to electronics guys but it seems it isnt
ThePanMan
Joined Mar 13, 2020
950
It's not difficult. Just wondering why. And without enough information as to how the piezo is driven we really can't give you a conclusive answer.
dc voltage setting just basic dmm
on current ma setting it was going up to 60ma and all over the place
Since a piezo is an AC device with a frequency possibly in the 10's of thousands of hertz, a simple meter set to AC "MIGHT" and "MIGHT NOT" give you an accurate reading. However, on DC - you're going to see things flying all over the place with regards voltage since most meters sample rather than read out a continuous reading.
35,181
It is simple electronics but your approach is making it more complex than it needs to be.
Tell us the length of time desired. Is it seconds, minutes, hours? What resolution and accuracy is required?
dave321
Joined Dec 10, 2010
65
it could be seconds , minutes or hrs, whatever i want at the time.
this is simply set on the kitchen digital timer.
just want to use the output to the piezo?transducer? to trigger another circuit at 9v,
which i will turn off manually when i want.
this should have been clear from my initial post but maybe not.
35,181
It is clear in your initial post what you are trying to do.
It is also clear to us that a kitchen timer is not designed to do what you are trying to do.
There are digital timers on the market that has relay switch contacts for output.
As an example:
https://www.amazon.co.uk/dp/B07KPZVKPM/ref=sspa_dk_detail_1
Alec_t
Joined Sep 17, 2013
15,156
Try measuring the piezo voltage with your meter set to AC Volts. You should get a better indication, but probably not accurate.
dave321
Joined Dec 10, 2010
65
As an example:
ah, many thanks for that link, i believe 12v versions are available so maybe that would be better and more suitable.
i think you have found me a solution
many thanks
